Execute Powershell Scripts on remote Machines with individual Credentials (from C. repository)
we use already successfully "PowerShell (Local)" scripts to start/stop services on remote Windows machines with the command:
Get-Service "spooler" -ComputerName $IP$ | stop service; Get-Service "spooler" -ComputerName $IP$ | start-service
We use the menu Macros/Script/Tools by rightclick on an entry and to do this, the user of RDM must have permissions on the remote machine (e.g. domain administrator).
How is it possible to run a PowerShell script with other credentials, optimally directly with reference to the RDM credentials repository ?
This script should be also called directly via a right click on an entry (e.g. Macros/Script/Tools).
When I create a Powershell/Powershell Remote Console Script in RDM, I can't select it directly on an entry to execute it.
With this thing, it should then be possible to execute other powershell scripts with predefined credentials (e.g. shutdown/restart remote clients etc.)
Thanks for your great Support.
Adriano
This is a feature that we've just added in RDM beta. You could give it a try here:
http://remotedesktopmanager.com/Home/ThankYou?f=RDMsetupBeta
Hi David,
sorry, I've installed the RDM Beta (v11.5.8.0) but I can't find the new feature. Where I can find it exactly ?
OT: The new/changed Design looks fine!
Adriano
When selecting your entry to execute the remote powershell on, you should see the powershell entry in the dashboard:
You can also access the remote powershell in the context menu of the entry > Macro / script / Tools, then select your remote powershell.
In the remote powershell you must specify the "use session credentials" option:
When executing the remote powershell on the entry, it should use its host, username, domain and password.
Is this what you are trying to do? If not, we might require a few screenshots or a small video of your issue. Thank you!
Closed
