KeyAgent to load keys from private vault
I'm trying the beta 11.1.10.0 with the option "KeyAgent to load keys from private vault"
But there's no option to add my Private Key from the private vault in the key agent manager, only able to add a file from my computer.
Thanks
All Comments (2)
What this means is that the option in the "advanced" tab of the private key entry will work properly with the private vault:
When opening the key agent, it will automatically try to load this entry's private key.
Wow!! Nice work fine
