Unable to connect using gateways
Has there been any improvement on this connecting using a gateway? I just downloaded the IOS app yesterday and since all my connections use a gateway, I have not been able to connect to any of the computers I need to connect to. I have an enterprise license and connect to a SQL server for my connection. That part works fine.
I saw in a 12/15/15 post that the Gateway functions were there but not functional.
All Comments (7)
What are your Gateway settings in your RDP sessions? Not all the gateway settings are yet supported on iOS. The gateway won't work if your gateway settings use these options "Login method", "Use Gateway credentials" and "Open Gateway only when unable to ping host".
Olivier Désalliers
When I changed the gateway setting back to the defaults that were loaded during the load of the session from the sql server I can get to most of the clients.
I am trying out the off-line mode and am not having any success with it. I have set up my sql server and get the session downloaded from it correctly. I have the sql server set to off-line mode read-only. When I go to another wifi location the program acts like it is reading the data from the local off-line data store, but no sessions show in the sessions list. The data source shows rdmsql(Offline). rmdsql is the name I gave the data source.
Any suggestions?
I pretty sure you already did it but did you setup up in the data source settings of your SQL Server data source to accept the offline mode? To setup your data source settings to accept the offline do the four first steps describe here:
http://helpandroid.remotedesktopmanager.com/howto_usetheofflinemode.htm
Can you also analyse your data source cache with the app? Here the steps to analyse your data source cache:
1. Go to the Data sources tab
2. Tap the "i" button on your SQL Server data source
3. Tap "Manage Cache" in the popup.
4. Tap Analyse in the Manager Cache view.
Once the analyse is done can you tell me if the "connections rows" is not 0.
Olivier Désalliers
Connection Rows: 148
Database version: 9
What is it written in the table view? "No connections to show" or "Not connected"?
Can you also send your application logs with app. Go to settings -> logs. Maybe it will help us pinpoint the problem.
Olivier Désalliers
It says 'Not connected!' in the tree view pane
We modified the way the connections are refreshed in the next version. I'm not totally sure it will fix your issue but you will now be able to go in offline mode with a button in a new menu available in the main connection view.
Olivier Désalliers
Closed
