IPad connection issues
Hi.
Glad to finally see this on iPad. However, I seem to be running into some issues. I cannot connect to any rdp sessions, it just tries and eventually times out. I can make a connection using the ms rdp from my iPad. I'm running 1.1.0. Not sure what I'm missing.
Do you use RD Gateway in your sessions? It's not yet supported, it will be supported in the next version but "Login method", "Use Gateway credentials" and "Open Gateway only when unable to ping host" options won't be available.
Could you also send us your logs with your app in Settings -> Logs.
Olivier Désalliers
No, I'm not using rd gateway
Logs sent.
Closed
