Serial not saving
Brendo
Disabled
Adding serial number into datasource (SQL) is not saved
- Administration -> Data Source Settings
- Serial
- Serial (Site/Global)
Seems to be an issue for last few stable versions also. Jump Serial saves ok
All Comments (6)
Hi Brendo,
What type of data source are you using?
Brendo
Disabled
Oops! Forgot that
Running latest bets 10.9.5.0. Issue also occurs in 10.5.4.0, latest 10.6. Enterprise edition
Data source Sql server
edited by Brendo on 7/3/2015
Hi Brendo,
I was able to reproduce your issue.
A bug ticket has been opened to our engineering department.
Thank you and have a nice weekend.
This will be fixed in the next version of RDM.
Hi Brendo,
Could you give a try to RDM 10.6.7.0
http://remotedesktopmanager.com/Home/Download
Brendo
Disabled
Looks to be working correctly. Thanks
