RDP Manager and RDP connection whit Proxy settings
Hello everybody :)
is it posible to add proxyserver settigns to an rdp connection because i cant find the settings ProxyAddOn the dll addet to RDP folder.
But i cant find any settings to add it.
Thx for the help
All Comments (5)
You can pre-configure a proxy in the RDP connection. In the VPN/Tunnel/Proxy section located when you edit a RDP connection. Select "Use existing VPN" or select you VPN/Proxy type.
HI Thx for theawnser maby iam to stupid but i dont find it where i can add the creditals like
proxy:lxxxxx:8080
user: test
password:secret
i wanna reach a external rdp pc wht ip trought the company firewall :)
@ settings/advancedsettings i only find
Gatewayserver settings angeben
Server: costum login i add all infos but its not working
How do you configure your proxy with mstsc (Microsoft RDP client)? Is it a VPN or another application?
Hello if i use mstsc i cant connect to a pc outside of a network .
i only connect to server in the company.
but i wanna go to an pc outside of the company network.
so i need to add Proxy credentials.
There is not built-in proxy in RDP. You need to use an ssh connection or a VPN. As far as I know there is not solution if you can make it work with mstsc.
