I'm not sure if this is possible, but I'm looking to generate a lot of connection, group and credential objects from information stored in a database. I've noticed that the file being generated is only XML, but when I write the information I think I need, RDM throws a XML serialization exception (my guess is, I'm doing something wrong).
Before I go too much farther, is it possible to use the SDK to generate this information (and hopefully have it generate a file that is usable)? If so, what classes would be a good place to start looking?
Thanks
We don't have and SDK to generate the xml file but maybe you could try the power shell?
Thanks for the suggestion I will also check the Power Shell hope it helps
