Im getting a a strange window in top left screen witch covers up application. It appears to show programming data of some sort.
Something is wrong.....
David Bannerman
Linfield Christian School
Could you try a reset Layout?
The pop up window covers everything from ADMINISTRATOR tab left. I cant get to anything on left side.
David Bannerman
Close RDM an d go in %LocalAppData%\Devolutions\RemoteDesktopManager Delete all the lyt files (layouts)
After a reboot and deleting lyt files, the program looks like its not connecting to my data sources. Got 0 entries and I have no idea what went bad. Can I re-install software? I pay for the online database backup. Maybe I should stay away from the Beta releases.
David Bannerman
I'm not sure it's related to the beta version. What data source type do you use? Could it be possible that it just referring the wrong file in File->Data Sources?
Does your layout issue is fixed?
I am sending email message to support with complete details. Forum back and forth is going to take to long. Thanks anyway.
David Bannerman
No problem
