i'm using version 10.0.17.0 and i created a new folder and when i right clicked to add a session nothing happens. I was able to create a session in the root then drag it into the new folders and was then able to right click and get the menu
Hi ss18,
We are currently working in this issue. I'll keep you post.
edited by jfdagenais on 12/2/2014
It's now fixed internally and will be available in the next beta release.
Until then there is a work around possible. The folder must have at least 1 session in it for it to work.
You have a few options:
- Drag & Drop a session into it (thanks ss18)
- Select the folder and hit "Insert" key
- Select the folder and click the "new" icon
Stéfane Lavergne
We have a new version available:
http://download.devolutions.net/Devolutions.RemoteDesktopManager.Bin.10.0.18.0.zip
http://download.devolutions.net/Setup.RemoteDesktopManager.10.0.18.0.exe
Stéfane Lavergne
that fixed it. thanks!
