10.0.12.0 Issues with view & navigation setting
I have the ribbon collapsed and navigation docked / hidden.
After every upgrade (this has been happening for a long time) I must re enable the navigation, re-size it the way I want it and reset it to auto hide. It would be really nice if this was not lost every time.
On this particular build this became even more or a pain because clicking View > Layout in the collapsed ribbon does nothing. I could only add the navigation back after expanding the ribbon.
All Comments (6)
Could you close RDM and go in %LocalAppData%\Devolutions\RemoteDesktopManager. Delete all the .lyt except RemoteDesktopManager.lyt which is the current.
done
We will see with the next update. Perhap you could backup the remotedesktopmanager.lyt before the upgrade and replace it if it's broken.
will do, thanks
No luck.
Same behavior as original post this morning after the update to 10.0.14.0
What happen when you overwrite the previous backup and start RDM?
Closed
