RDP Connection is not going to secondary monitor
I'm using a Dropbox source for my RDP connections because I'm using it home and at the office but I have a problem at home.
I have the setting "Display > External > Secondary monitor" and at the office it work as it should, there the RDP connection goes full screen on my secondary monitor but at home it just pops up in full screen on the primary monitor.
Kind Regards,
Noiden.
Could you try without the full screen mode just for a test?
Ye, same error, tried different resolution and tried both primary, secondary, monitor #1 and monitor #2 and the window just pops up in the primary monitor.
Could you verify the application logs in Help->View Application Logs?
