Using AutoIT and AutoHotKey scripts on remote host
Hi Fellow users,
I've build some pretty basic scripts in AutoIT and AutoHotKey (sending basic keystrokes and so on).
But they dont run on the remote server, instead the run on my local PC!
Isn't it possible to run them on the selected host?
Otherwise this seems a pretty useless feature to me.
All those scripts run locally since they don't support the remote execution. However if you install RDM Beta and RDM Agent you will be able to run it on the remote host:
