I have a problem with the Beta V.6.9.4.0. I can't resize the windows in the remote sessions. It doesn't matter if it is a Server or Windows XP or W7. You can maximize the windows in the remote sessions, but you can't change the size with the mouse. Moving works fine.
Kind regards
Holger
edited by dhervieux on 1/17/2012
Could someone try to click and drag a shortcut on their remote session desktop.I suspect that the mouse down is interrupted.
I am unable to drag the desktop icons either.
Could you send me you remotedesktopmanager.cfg file by email? it's in %LocalAppData%\Devolutions\RemoteDesktopManager
Can you also do a test for me, in remotedesktopmanager.cfg, set AppActivateAutoFocus to false and retry. Just make sure that RDM is closed before editing the setting.
Could you try this version?
http://remotedesktopmanager.com/download/Setup.RemoteDesktopManager.6.9.5.0.exe
This don't work. I couldn't move any Icons on the desktop.
This brings no bettering.
Is it possible to get a ZIP-Version?
Hi David,
with RDM 6.9.5.0 the Problem is gone.
the zip is http://remotedesktopmanager.com/download/Devolutions.RemoteDesktopManager.Bin.6.9.5.0.zip
Hi David,
Great, it works again. Drag Desktopicons, resize and moving windows.
Thank you for your fast help.
I was unable to reproduce the problem but I've found what might be the source.
The problem is also gone for me. Thanks to David and the Devolutions development team.
