Greenbow Problem
I use Zywall VPN Client (v3) and in RDM it works great with the Greenbow add-on, exept for one thing:
On session close I would like it to end the session, but it closes the whole program. The only way to control it is to manually close the vpn connection. I do not believe yhis is correct behavior..?
All Comments (5)
D you mean that it closes RDM?
No, it closes the Zywall Client, sorry to not make that clear. Many times I have several vpn sessions open, and when the program closes - well, that's not so good ..
Ok, I get what you mean. We have a feature called vpn group. It's in the VPN tab page. You can give all your session the same VPM group name and RDM will only close the VPN when the last opened session (linked to the group) is closed.
Sorry, this seems not to work with different vpn sessions. It may work good if you open several servers in one location, but when I open vpn to two different sites, it does not close any until the last session is closed, then it shuts down the Zywall program. Also we often connect to vpn sitex without using RDM, this will also be a problem. This, I think, should be fixed.
We have v. 6.1.3
I don't see any other solution than controlling the VPN manually.
