Problems at UltraVNC Addon and Question to Sendkey
Hello again,
i still have 3 problems:
1. UltraVNC Embedded mode
if i want to start a VNC Session i got following error(attached file), but i have installed the Addon any idea?
2. If anyone starts a putty embedded mode session, everything is okay, but if you want to close the tab by clicking X in the upper right corner, the Window Close and minimize the Remotedesktopmanager.
3. Is there any possibilty to use more than one macro(send key) after connection?
We want to place the User and PW as a Sendkey macro, but after username and {TAB} the macro is to fast.
The password is typed before the passwordwindow gets the focus.
All Comments (7)
We require an add-on for embedded UltraVNC but this add-on must be installed in the Remote Desktop Manager folder. Unzip this file into the RDM installation path:
http://remotedesktopmanager.com/download/AddOn/UltraVnc1.0.0.0.zip
For the Putty problem, can you just post a printscreen to show me where you click. Have you try to close it directly from the tab page?
For the macro, we already added {Delay} to introduce a 300 ms of delay. I hope this help
Hi, iam back from hollidays.
for the Putty problem i posted a pic above this reply.
The Delay doesnt work... cause i have to write the Username than Tab (than i need a Delay cause of the TAB){Delay} Password but It doesn´t matter where i put the Delay, the Delay will always be at the beginning of Sendkey....
For the VNC i will test your solution
any news?
Hello again,
i tested your solution for VNC. i Think ive done the same as the Addonmanager will do.
i get the same error as before
i think as the rdm says it needs an vnc add on for embedded mode, could it be?
where can i get it?
we just have the normal vnc add on.
For this add-on, it has to be unzipped it the Remote Desktop Manager installation folder
Okay xD so the problem is all addons will be installed to appdata/remotedesktopmanager but the vnc addon only works on the installation folder hm.... what shall i do know with the 300 other users? =)
This is because it use an ActiveX and the ActiveX must be installed in the application folder unfortunately. This is the same problem with the Office add-on. Add on manager will install it a the right location.
edited by dhervieux on 10/25/2011
