watchguard ssl vpn add on problems
We need to integrate the Watchguard Mobile SSL VPN into RDM to get the most out of your product.
The client we use is Watchguard Mobile VPN with SSL version 11.7
Currently the add-on cannot find the WG executable wgsslvpnc.exe
The .exe exist at C:\Program Files (x86)\WatchGuard\WatchGuard Mobile VPN with SSL\
I tried both the manual and add-on manager to integrate it.
Love your product by the way.
thanks,
Joe K
All Comments (7)
Could you go in File -> Options -> Path -> Configure Installation Path -> Watchguard SSL VPN and specify the installation path of Watchguard SSL VPN.
I updated the field and now the SSL VPN client opens, the default path was the same as the manual path I entered.
However it does not populate the server/username fields on the client which I filled out from the connection-->general tab.
Is there some kind of macro we need to program?
thanks a lot!
Joe K
This should work, could you please post some print screens of your entry.
thanks a lot for your help.
I got it working by completely exiting out of the watchguard ssl vpn app then opening a new instance through RDM.
The fields populated OK.
Password field needs to be updated with each new connection.
Bumping this thread. Anyway we can add a password field for this Addon? Currently we have to provide any VPN users the password to be typed in manually.
jadevries83
Disabled
Is this already possible. Im also having problems with auto filling the password field!
I believe that the Watchguard SSL VPN client does not allow us to specify a password through a command line. You could try using a macro to fill in the password. You can access them in the Events tab of the entry.
