Using PVM credentials
I'm a little confused as to why Credentials are in a separate area to the Data Entries. In the PVM online help it states "...allows you to to set multiple sessions to a specific set of credential...". So it looks like a Credentials entry can be shared with multiple Data Entries items. But how?
Thanks,
Chris
All Comments (2)
Hi
There is an option to display the credentials within the data entries
As to linking credentials, the only "session" entry type in PVM is the Web entry
Link to a credential as follows
Maurice
Hi Maurice,
Thanks for the quick reply. That's what I was looking for, thanks.
Chris
