1 vote
Product: Remote Desktop Manager / Devolutions.PowerShell
Tested version: Devolutions.PowerShell 2026.3.3 on macOS
I’d like a supported way for PowerShell scripts or integrations to retrieve the decrypted value of an RDM Credential entry whose credential type is Connection String.
I’m building an integration with the VS Code SQL Server (MSSQL) extension. The goal is to use RDM as the source of SQL connection strings, rather than storing them in VS Code settings or maintaining them in multiple places.
With a Connection String credential entry and Allow password in variable enabled, I found that:
ClearTextConnectionString is empty.
SafeConnectionString is present but encrypted.
Get-RDMEntryPassword and Get-RDMSessionPassword fail with “Object reference not set to an instance of an object.”
Could you support retrieving this credential type through an existing cmdlet, such as Get-RDMEntryPassword, or provide a dedicated cmdlet/API? It should respect the entry’s permissions and RDM’s normal security and audit controls. macOS support would be especially helpful; Windows support would also be useful.
Expected result: An authorized script can retrieve the decrypted connection string for an eligible entry, while ordinary entry listing can still return metadata without exposing secrets.
Hello @anderslund1,
A ticket has been opened to enable fetching an entry's decrypted connection string. We'll keep you updated as progress is made on the task.
Christian
