RDP problem with RDG
With the Linux version V2026.3.2.1 of RDM, I’m having an issue where mouse clicks are apparently being transmitted very late or with a noticeable lag.
I didn’t have this problem with version V2026.3.1.2 (which is very confusing).
I connect to my employer’s network, which uses a remote desktop gateway (RDG).
When I’m on my personal device on the local network, I don’t have this problem.
Does anyone have any idea what might be causing this?
Thanks.
I’m using the latest Ubuntu 26.04 LTS.
All Comments (9)
Hello
Is it just mouse "clicks" that are laggy, or is all mouse input lagging?
Thanks and kind regards,
Richard Markievicz
Hello Markievicz,
now that you mention it, yes—all inputs are delayed. Is this a known issue?
Thanks
Chris
Hello
Yes, I think so. I haven't tested this on Linux but we've seen the same thing on other platforms.
If you have a mouse that has a very high polling rate, it simply sends too many input events and overloads the Gateway's WebSocket transport that causes lag.
As a workaround you can try to switch the Gateway transport to "RPC", but this may not work if the Gateway requires WebSockets. It's worth trying:
What I don't understand is why this would be a regression. You wrote:
With the Linux version V2026.3.2.1 of RDM, I’m having an issue [...] I didn’t have this problem with version V2026.3.1.2
But I guess the older version was actually 2026.2.x? It might explain things, because we switched UI frameworks in that gap and perhaps our new framework is handling the high polling rate and our old one wasn't. Or, is it simply possible that you got a new mouse?
Anyway, I'm sure this is the problem and I'm linking a ticket to this thread for the RDM Linux team. We will post back once the underlying issue has been corrected.
Please don't hesitate with other questions or comments, and I'm sorry for the inconvenience
Richard Markievicz
Hello Markievicz,
Thank you very much for your help.
I tried RPC. The problems are still there. I don't have a new mouse.
The older RDM version, V2026.3.1.2, works. Version V2026.3.2.1 has the error you mentioned.
1.2 at the end works.
2.1 at the end does not work.
I haven’t tried a 2026.2.x version because 2026.3.1.2 works.
Thank you very much,
Chris
Hi Chris
Thanks for the update. You're right to push back on this but I'm still a little bit confused.
I've found this issue in FreeRDP which closely matches what you describe. It was a regression on their side introduced in version 3.32.2 and as far as I can tell fixed in 3.33.0.
But there is one thing I don't understand, are you sure about the RDM version you describe? Because:
RDM 2026.3.1.1 -> FreeRDP version 3.31.1
RDM 2026.3.1.2 -> FreeRDP version 3.32.2
RDM 2026.3.2.1 -> FreeRDP version 3.32.2
So, both RDM 2026.3.1.2 and 2026.3.2.1 have that issue.
I don't rule out a mistake on my side when evaluating that. One other thing; this should also be worked around by using the RPC transport but I've found another issue where RDM may not honour your selection here (there are cases where it will unconditionally enable the HTTP transport). I'm fixing that right now.
The next step on my side is to upgrade our FreeRDP integration to the latest. 3.33 was released last week but there were many bugs reported and I'm expecting a bug fix release from them this week. So I will try to wait a couple of days and see if we get a newer release.
Thanks for your patience
Kind regards,
Richard Markievicz
Hello again
Ok, yes, I inspected the actual release installers and there is a mismatch between what I saw in the manifest and the actual build. Indeed this issue was first shipped in 2026.3.2.1 so I'm sure this is your bug.
I will get this fixed ASAP. Thank for your patience.
Kind regards,
Richard Markievicz
I'm glad to hear you found something.
Let me know if there's anything you want me to test.
Kind regards
Chris
Hello again
I'm confirming that the underlying issue will be fixed by 2026.3.3.
Thanks for your patience, and please don't hesitate with other comments or questions
Kind regards,
Richard Markievicz
thank you very much for your help. I'll check back from time to time to see when the new version is released.
All the best
