saving stuff to the HD does not auto load api code
  1. put psu in edit mode
  2. make a change to an api
  3. test api = old code still responding
  4. go to files and click restart endpoings
  5. test api = old code still responding
  6. go to api's click reload apis
  7. test api = new code active
Hi Matthew,
Thank you for the clear steps. They look like the behaviour you reported in your topic "2026.2.5 - auto reload not working".
Our development team has found one cause of it on Windows. When an API's script is in its own file and you save that file, PowerShell Universal detects the change but fails to match the file to its endpoint. The change is marked as resolved on the Configuration Changes page, while the running API keeps the old code. The correction has been made, but it is not in a released version yet, and 2026.3.4 does not include it. It covers the automatic reload on save only, so it does not explain why reloading Endpoints from the Files page did not apply your change either.
For now, Restart APIs on the APIs page is the step that applies your change, as your own test showed. It stops and restarts all of your APIs on that server, not only the one you edited.
To confirm this is the defect you are hitting, and to look into the Files reload, could you tell me three things?
1. Your current PowerShell Universal version.
2. Whether this API's script is in its own file, or written inside endpoints.ps1.
3. Whether Configuration Changes marked the change as resolved before you restarted the APIs.
Michel
Michel Audi
i reported this for 2026.3.3.0, looking forward to 2026.3.5.0
Hi Matthew,
Thank you for clarifying that you reported this on 2026.3.3.0. That build contains the automatic reload defect I described, although I still need to know how this API's script is stored to tell whether it explains your test.
The correction has not been added to the 2026.3 updates yet, so I cannot confirm that the next update will include it.
Reloading Endpoints from the Files page is a separate issue. It matches what you reported in August in your topic "Reload endpoints does not restart endpoints", which is still open with our development team. The automatic reload correction does not cover that step.
For now, Restart APIs on the APIs page remains the step that applies your saved change. It restarts all of your APIs on that server.
Is this API's script in its own file, or written inside endpoints.ps1? The correction covers a script in its own file.
Michel
Michel Audi
