Connection filter is broken after selecting filtered connection
A fix for this issue has been implemented in version 2026.3.2.1
Implemented
In the latest version the new filter field is broken, when I filter for a connection, open the ssh connection and click back into the filter, I can't type anything.
I can click on the X, which removes the content but clicking again in the field and try to type, it doesn't work.
After alt+tab and going back it's working again.
Remote Desktop Manager 2026.3.1.2 64-bit
Runtime: .NET 10.0.13
Platform: Debian GNU/Linux 13 (trixie)
Allocated memory: 327 MB
Thank you for the report.
This is a known issue in RDM Linux. After you open a session from a filtered result, the filter box looks focused but no longer takes keyboard input. What you type is sent to the open session instead. Our QA team has reproduced it, and it’s logged with our development team.
I’ll update you as soon as a version with the fix is available.
Carl Marien
thanks
Thank you for your patience while our team looked into the issue you reported.
I'm happy to let you know that the latest version of Remote Desktop Manager for Linux (2026.3.2.1) includes a fix for this problem. You can download it from our website here:
https://devolutions.net/remote-desktop-manager/download/
Once you have installed the update, could you please test it in your environment and confirm that everything now works as expected? If the issue persists or if you notice anything unusual related to the same original problem, just reply to this message with a few details, and we will be glad to look into it further.
Maxim Robert
