2026.2.5 - auto reload not working
the file detector thing runs, but i still have to go to files and click reload endpoints or whatever it is i am working with to get psu to redploy whatever
All Comments (7)
Hello @Matthew Morrow
Thank you for reporting this.
From your description, the file detector appears to be noticing the change, but PSU is not automatically applying it and you still need to manually use options such as Reload Endpoints.
We will reproduce this behavior in our lab using PSU 2026.2.5 so we can properly document the results and prepare the case for internal escalation if the behavior is confirmed.
To make sure our test matches your scenario as closely as possible, could you please confirm:
• Is Auto-reload enabled under Settings > Files > Configuration Changes?
• Are you modifying the PSU files directly on disk, through VS Code, or by another method?
• Besides endpoints, have you noticed the same behavior with any other PSU resources?
• What hosting method and operating system are you using?
We are also working through the different reports you have shared, so we appreciate your patience while we validate each behavior individually and make sure the appropriate evidence is collected before moving them forward.
Because this is a public forum, please sanitize all evidence before posting. Remove credentials, tokens, license keys, cookies, private keys, full connection strings, email addresses, usernames, customer data, tenant or account identifiers, internal domains, hostnames, IP addresses, and private URLs. Please do not upload unredacted HAR files, memory dumps, database backups, or complete configuration files to this public thread.
Ruben Tapia
i will capture that next time it happens
also experienced it in 2026.3.2.0
dev environment
vscode
edit endpoint
go to site and endpoint doesnt know about the new code
auto reload enabled
shows the change resolved in /changes
new code does not show up in the editor
git editing button is = true
i have to go to reload config files to get it to see the changes
We completed the lab testing for this behavior using PSU 2026.2.5 in Docker.
We were able to partially reproduce the issue. With Auto reload enabled, multiple external configuration changes were detected at the file level but were not automatically applied to the running endpoint. The behavior was repeatable across the final three test iterations.
We also confirmed that manually using Reload Configuration Files applied the latest change successfully, and the runtime consistently returned the updated endpoint version afterward.
One difference remains between our lab and your report: we did not reproduce the Configuration Changes history or the “Resolved” state you described, so we are keeping the result classified as partially reproduced rather than treating it as an exact match.
At this point, we have enough technical evidence to move the case forward for internal escalation and further review.
For now, the manual reload remains the validated workaround for applying the configuration changes.
Thank you again for your patience while we worked through the reproduction.
Ruben Tapia
This is super important because when i have my AI Agent editing code, and then the 'thing' does not deploy and the agent checks is work, the feedback loop gets messed up and then it doesnt know if the code change is a success and then that causes the AI to sprawl and causes me to sprawl, where as before i was the one watching it not work and then recycling app pools or restarting servers to get it to work manually. The feedback loop for AI is not as forgiving.
I have to do silly stuff like write-host "Trace start v1", then the agent has to match all that up and remember to go v2 so it can see if the logs are up to date :(
This was on 2026.2.1, but here's my experience:
  • I added authentication and a required role to an app
  • committed the change (to dashboards.ps1)
  • Created a PR and merged it
  • Waited a minute and made sure the change was registered in my Prd PSU environment
  • Auth was still not required in the app in Prd.
  • Restarted the app (from the apps page in the admin console)
  • Still no required auth
  • Went to Config/Files and restarted the apps fixture.
  • Now auth was required.
I would expect that when the app restarts after the git merge, changes to auth would immediately be active.
Hello @Matthew Morrow @mshepard70
Thank you for the additional details and for explaining the impact this has on your workflow.
Based on the evidence collected so far, including our partial reproduction in PSU 2026.2.5 and the additional behavior reported in this thread, the case will remain escalated internally and tracked for consideration in future patches.
In parallel, I will continue running additional tests on my side to better understand the remaining differences, particularly the Configuration Changes / Resolved behavior and the conditions under which the runtime continues using the previous code.
If I obtain any additional reproducible findings that help narrow the behavior further, I will add them to the escalation.
Thank you again for your patience and for providing the additional context.
Ruben Tapia
