[2026.3.0] status filter in jobs does not filter
A fix for this issue has been implemented in version 2026.3.3
Implemented
when i select filter = error, it refreshes but the filter is not applied
All Comments (4)
Hello @Matthew Morrow
Once again, thank you for taking the time to report these findings in 2026.3.0. We really appreciate your continued feedback and contribution.
We will reproduce the Jobs status filter behavior in our environment and validate whether the issue is specific to the Error status or affects other status filters as well.
Once we have the reproduction results, we will continue the investigation with the Development team and update this thread with our findings.
Ruben Tapia
We completed our technical review of the Jobs status filtering behavior you reported.
Our findings identified a mismatch between the status selected in the UI and the status values used by the filtering logic. This explains why selecting Error can refresh the table without applying the expected filter.
We have enough technical evidence to move this case forward for internal escalation and Development review.
Thank you again for helping us identify this behavior in 2026.3.0. I will update the thread when we have additional information.
Ruben Tapia
Same issue happening on my environment after upgrading to PSU 2026.3.1. When I select a job status filter, the job list is refreshed but the filter isn't applied. Is there any news regarding this bug?
@sergioponstur I've just raised an issue for this issue. We will take a look to see if we can get this resolved for 2026.3.2.
Adam Driscoll
