PS cmdlet that backs the concurrent-session indicator on RDP/Web entries
1 vote
The RDM GUI shows on RDP/Web entries when a session is currently open via the "play" icon (hovering shows the connected user/workstation). We'd like to get this same information via PowerShell.
Your service team confirmed there is currently no cmdlet for it. Get-RDMOpenedSession only returns my own local sessions, not those of other users.
Our team uses a PowerShell tooling daily and wants to check before connecting whether a colleague is already on a system.
Would be great to see this released.
Hello @lucaoutma,
A ticket has been opened to enable fetching info about whether an entry is opened by other users. We'll keep you updated as progress is made on the task.
Christian
Thank you for your patience while our team looked into the requested feature.
I'm happy to let you know that the latest version of the Devolutions.PowerShell module (2026.3.3) includes the requested feature. You can get it from the PowerShell Gallery here:
https://www.powershellgallery.com/packages/Devolutions.PowerShell
If the module is already installed, you can update it with the following command:
Update-Module -Name Devolutions.PowerShell
Once you have installed the update, could you please test it in your environment and confirm that everything now works as expected? If the issue persists or if you notice anything unusual related to the same original problem, just reply to this message with a few details, and we will be glad to look into it further.
Maxim Robert
