PowerShell Universal Community Call - August 2026
Our next community call will be Wednesday, August 19th, 2026 at 11am central US. We will continue to host these on the third Wednesday of the month.
These calls are hosted on our Discord server. https://discord.gg/Sb5ngcjkj4
Agenda
Feel free to comment below to help drive the agenda.
  • PowerShell Universal 2026.2.3, 2026.2.4 and 2026.2.5
  • PowerShell 7.6.5 security fixes
  • VS Code Extension updates
  • Devolutions.PowerShellUniversal vs Universal module info
  • devolutions/powershell-universal Docker Container
  • PowerShell Universal 2026.3.0 Details
Adam Driscoll
All Comments (2)
Meeting Notes
We had a well-attended meeting with some good discussion. I talked about the above topics and where to find the new artifacts:
We discussed some of the new versions. 2026.2.5 will be out soon with a patch to the PowerShell SDK's NVD - CVE-2026-70337.
I also gave a demo of the PSU 2026.3.0 admin console refresh. Showed off the general look and feel, search capabilities and table unification. We talked a bit about Devolutions Agent integration.
  • Discussed performance of jobs launched from APIs using Invoke-PSUScript
    • Persistent job environments coming in 2026.3 that should help
    • Will support MCP tools
    • Question about environment recycling for jobs that we need to follow up on
  • Discussed the benefits of idle environment recycling that we could implement in a future version
  • PowerShell 7 jobs are much slower to start on Windows than on Linux (7-15 seconds vs 2 seconds)
  • User discussed issues with saving apps
    • Sometimes app reload shows a blank page
    • Sometimes (especially on a phone), the session timeout modal is just displayed instead of the app
    • Timeout lock when saving sometimes (sees to work fine but error shown)
    • User will open bug\support forum for each item
  • Docs - Search is not scoped to PSU by default. Use the Filter -> All Docs button to switch to just PSU search
  • Blocking\Rate Limiting Discussion
    • PSU can already rate limit exact URLs but would be nice to have built in rate limits for things like "login", "admin console" without too much rate configuration
    • Would be nice to limit apps\admin console to specific Kestrel listeners
  • Multi Git Repo
    • user has multiple teams and looking for a good way to configure that in PSU
    • Not great support at the moment, submodules probably easiest
    • User will open a feature request with some more details
  • Certificate based auth issues
    • User occasionally gets TLS issues with clients connecting to APIs
    • User will open a support or bug in the forums to investigate
  • RBAC Reporting
    • A user would like better reporting of RBAC in apps so its easy to see who has access to what
    • General RBAC reporting would be good
Adam Driscoll
Thanks Adam.
Looking forward to 2026.3
