Our next community call will be Wednesday, July 15th, 2026 at 11am central US. We will continue to host these on the third Wednesday of the month.
These calls are hosted on our Discord server. https://discord.gg/Sb5ngcjkj4
Some agenda items that have been brought up. Feel free to comment below.
Pester Support in PSU
2026.2.2 and upcoming 2026.2.3
WinForms to PSU App AI Skill
Adam Driscoll
Meeting Notes
I talked about the 2026.2.2 and the upcoming 2026.2.3 a bit.
I did a demo of the WinForms to PSU App AI Skill
Pester Support
Attendee described environment of 300+ scripts with a small team and heavy reliance on Pester
Desires something like a CI\CD pipeline environment without using GitHub Actions
Pain points
Overall usability (not very mature)
Basic output - No much to gain running in PSU
Desired functionality
Some way to tie tests to feature groups, resource groups, individual resources (API endpoints, apps, etc)
Triggers for pester tests when code changes
Nightly runs of Pester tests
Triggers for failed test runs
Discussed best ways to handle test assignment
Pester\PSU Tags - Possible but could get messy
Naming Conventions - Maybe easy to do but also could cause unexpected side effects
Test Manifest - Most rigid but maybe easier to support
High Availability
Question around general success of high availability
Attendee mentioned success with Docker Compose, PSU and PostgreSQL
Some discussion around the best database to use
Similar performance for PG and MS SQL
MS SQL used more often and typically more of a focus of the dev team
PG starting to be used more and is getting some more attention from dev team
An attendee mentioned that PSU does not survive database downtime well
Talked about how Notifications are coming to the trigger feature to get info about admin console notifications
Rate Limiting Problems - Captcha issue
Rate limiting and captcha configuration can be hard because not all internal URLs are well documented
Custom APIs should be rate limited and internal URLs should be allowed through
Blazor Hub
Dashboard Hub
Internal Components URL
Easier configuration of PSU's built in rate limiting for custom APIs
External\Internet Facing PSU Instances
There was a question around how users expose PSU to external networks
Attendee described the use of Azure API Management to surface some APIs to external services
Skills
An attendee is looking for a skill to create a custom App components
We have an internal experimentation around this that we can formalize and publish
New-UDUpload
Multifile support is desired
2gb limit is a blocker
Workflow
Not enough there. Needs more features
Not everyone had played with it yet but will give feedback when more time allows
Approvals would be awesome
Approvals via slackops is ideal
Agents
We are building PSU support in devolutions-agent (open source)
We are taking advantage of PSRemoting to be able to service event hubs-style features as well as run jobs
Adam Driscoll
