Devolutions Cloud web interface integrate with Bitwarden for authentication.
1 vote
the Bitwarden entry is not currently supported directly in the Devolutions Hub Business web interface for launching and pushing credentials to an RDP session. To use this workflow, you will need to open the session through Remote Desktop Manager or, at minimum, Devolutions Launcher.
All Comments (2)
Good Morning @hnn
Thank you for the request. I will open an investigation ticket and review this with the team. I will update this thread with any updates.
Thanks for the suggestions
At this time, direct integration of Bitwarden entries for authentication and credential injection through the web interface is not planned or supported. To use Bitwarden credentials with your RDP sessions, you will need to continue using Remote Desktop Manager (RDM), or at a minimum, Devolutions Launcher. The web interface does not offer this workflow natively, and there is no roadmap for this feature at the moment.
Sébastien Aubin
Product manager - Password Management
