Devolutions Cloud Free Connection
When setting up the connection, the configured URL is used, and the vaults can be used as desired. However, after restarting RDM, the host URL is changed to the subdomain, after which the vault can no longer be used in the Free version.
Currently, the connection must be reconfigured after every restart.
Connection Settings before restart
Error after restart
Connection Settings after restart
Recommended Answer
Could you update RDM Linux to version 2026.1.2.2? A fix has been pushed in that version.
You may have to recreate the Devolutions Cloud Free data source in RDM.
Let us know how it goes.
Érica Poirier
All Comments (2)
Érica Poirier
Hi, everything is working now after the update. Thank you
Ends in 4 days
