[BUG] Parameter Sets when setting schedule
Product: PowerShell Universal
Version: 5.6.13
When configuring parameter sets, simply running the code works fine. A modal pops up and the parameter set can be selected.
When setting a schedule, the modal pops up, but changing the parameter set locks the admin portal and it requires a refresh.
I’ve used a simple code to test and added a short video here
    .SYNOPSIS
    Test Parameter Sets
    .DESCRIPTION
    Test Parameter Sets
    .PARAMETER ParameterSet1
    $True will activate Parameter Set 1
    .PARAMETER ParameterSet1Parameter
    A test parameter for Parameter Set 1
    .PARAMETER ParameterSet2
    $True will activate Parameter Set 2
    .PARAMETER ParameterSet2Parameter
    A test parameter for Parameter Set 2
Param (
    # Set 1
    [Parameter(ParameterSetName = 'ParameterSet1', Mandatory = $True)]
    [Switch]$ParameterSet1,
    [Parameter(ParameterSetName = 'ParameterSet1')]
    [Switch]$ParameterSet1Parameter,
    # Set 2
    [Parameter(ParameterSetName = 'ParameterSet2')]
    [Switch]$ParameterSet2,
    [Switch]$ParameterSet2Parameter
All Comments (0)
