Product: PowerShell Universal
Version: 5.6.11Looking for help with making the layout of my form mobile friendly.
Currently on desktop the form looks like:
When on mobile however the fields get smooshed together and you cant read everything or edit fields very well and it just looks really bad. I was wondering if there is a way I set this up so the fields show as two fields in a row on desktop but when on a small screen or mobile all fields become vertically stacked.
If this isnt somehow automatically possible is it possible to determine the size of the screen viewing the app?
I can provide a sample of my code if that helps answer the question I have
is it not what -Largesize and -Smallsize parameters are for in UDColumn command ?
