Unselect row when using -DisableMultiSelect
I am not sure if this is by design or a bug. I am using the following code below but would like to be able to unselect a row after it has been selected. Essentially bringing all rows back to a default unchecked state. Currently when I select a row, my only option is to select another row. Could we make it so the selected row could be unchecked when using -DisableMultiSelect?
    $TableData = @(
        @{ Id = 1; Name = 'Adam'; number = Get-Random }
        @{ Id = 2; Name = 'Tom'; number = Get-Random }
        @{ Id = 3; Name = 'Sarah'; number = Get-Random }
    $Columns = @(
        New-UDTableColumn -Property Name -Title 'Name'
        New-UDTableColumn -Property number -Title 'Random Number'
    New-UDTable -Data $TableData -Columns $Columns -RemoveCard -ShowSelection -HideToggleAllRowsSelected -DisableMultiSelect
All Comments (1)
OK, I found a solution. I had to wrap the table in a New-UDDynamic and then check if row was unselected. If it was, then call Sync-UDElement to update the table.
    $TableData = @(
    $Columns = @(
    New-UDDynamic -Id 'DynamicTableSection' -Content {
        New-UDTable -id 'MyTable' -Data $TableData -Columns $Columns -RemoveCard -ShowSelection -HideToggleAllRowsSelected -DisableMultiSelect -OnRowSelection {
            if($EventData.Selected) {
                $myText = "$($EventData.name)"
            else {
                $myText = "No row selected"
                Sync-UDElement 'DynamicTableSection'
            Set-UDElement -Id "lblOutput" -Properties @{
                text = $myText
    New-UDTypography -Id "lblOutput" -Text ""
