Script duplication / Upgrade issues
(anonymous user)
Product: PowerShell Universal
Version: 5.5.3 / 5.5.4
Good Morning,
We are currently running version 5.5.3. we have two issues:
  1. Yesterday I upgraded it to 5.5.4
  • According to my MSI logs the installation was successful but the console for PSU was just stuck at loading.
  • I now rolled back to 5.5.3, and it is operating. But I am concerned, what went wrong? How to prevent it ?
The other issue:
  • it seems most script folder shows duplicates of the scripts
  • i.e. the one on the screenshot has one script physically on the file system, but shows the same script 8x on the PSU
  • (this is happening across all the folders, with all the scripts, so you can see how problematic is this)
Is there any way to prevent / reverse this?
Thanks,
Fabrice
All Comments (7)
Typically, the spinning is a result of the server failing to start fully. You should check the system logs for Failed to Start PowerShell Universal.
As for the scripts duplicating, take a look in your scripts.ps1 in the universal folder to see if there are duplicate entries.
Adam Driscoll
I am seeing a very large number of duplicates in my scripts as well. I cleared them out yesterday, restarted, and scripts.ps1 didnt have duplicates but there were still several scripts duplicated in the GUI.
Just looked again today, and we have a very large number of duplicates in scripts.ps1 again. I think I worked with you on a similar issue sometime last year on an earlier version but the duplication stopped.
also.. Just upgraded from 5.5.3 to 5.5.4
Support email sent.. I included files form our environment so I didn’t want to open straight to Github
I’ve open an issue to track this here: [5.5.4] Script Duplication · Issue #4847 · ironmansoftware/powershell-universal · GitHub
Do either of you have the Disable Auto Reload setting set in settings.ps1? I ask because in v5.6, I was seeing the file system watcher cause some weird behavior. Not duplication, but some inconsistencies in our integration tests. That said, I did not see this in 5.5.4, so it may be unrelated.
Adam Driscoll
We did not, but I just set it and will monitor
