Product: PowerShell Universal
Version: 5.4.1
IIS Install/SQL Express
AppPool ID: LocalSystemGreetings, first post here!
I am struggling through the initial learning curve of PSU and trying to use a gMSA to run a script. I’m experienced in the ways of gMSA, so it’s been properly created and the local machine has rights to retrieve the password. The account has both “Log on as a batch job” and “Log on as a service” rights.
I’ve registered the gMSA as a PSCredential variable (DOMAIN\user$), and checked the box for “Password not required”. No test can be performed on the credential, as for standard accounts. I assume this is a limitation of gMSAs.
I can select the credential in the script properties. All good. But when running the script, I get:
Error executing job: Failed to login user (1326). System.ComponentModel.Win32Exception (1326): The user name or password is incorrect.In the Windows Security Log, I see confirmation that IIS is initiating the logon, but finding “Unknown user name or bad password”:
Subject:
Security ID: SYSTEM
Account Name: MYCOMPUTER$
Account Domain: MYDOMAIN
Logon ID: 0x3E7
Logon Type: 4
Account For Which Logon Failed:
Security ID: NULL SID
Account Name: svc_gMSA$
Failure Information:
Failure Reason: Unknown user name or bad password.
Status: 0xC000006D
Sub Status: 0xC000006A
Process Information:
Caller Process ID: 0x1048
Caller Process Name: C:\Windows\System32\inetsrv\w3wp.exeThe IIS app pool is running under LocalSystem. From the docs I am understanding that if I were to run it under a custom service account, then I could not use alternate credentials.
How does one get this working?
Thank you!
Just to cover a few additional bases:
forwardWindowsAuthToken is set to “true”
Using a standard AD account as alternate credentials works fine
Tried granting additional User Rights in Local Security Policy: Impersonate a client after authentication, Replace a process level token, Obtain an impersonation token for another user in the same session
For what it’s worth, I am also having this issue and cannot get GMSA’s to run my scripts. Would love to see a solution for this!
Adam reports that the gMSA issues are solved and will be fixed in the 5.4.4 milestone!
Just confirming this works in 5.4.4.
Hi there!
It seems that the issue is back.
I tried to run scripts (simple script with whoami) with gMSA which I created PSCredential for using the DOMAIN\user$ format and also checked the box for “Password not required”.
Tried this in version 5.6.13 and in 2026.1.6.0.
But I get the same error as @matthew14 ..
The rights for log on as a batch job and getting pw on the server are granted.
Any hints for a solution or a version that fixes the issue again?
Thanks!
Hi all
In addition to my message above:
My PowerShell Universal Service runs as gMSA.
The account is member of the group that has permission to retrieve the other gMSA (I try to run scripts as) password.
I have the same problem.
Have you found a solution?
Thanks.
Thanks.
Hello dylegrand,
Thank you for following up.
The original gMSA issue in this thread was reported as resolved in version 5.4.4. However, other users later reported the same login error in versions 5.6.13 and 2026.1.6.
PowerShell Universal 2026.2.1 included a fix for running jobs with alternate credentials using certain username formats. The release notes do not specifically identify gMSA accounts, so we cannot yet confirm that this correction covers your scenario.
Could you please confirm:
• Your exact PowerShell Universal version
• The Windows Server version and installation type, such as MSI, IIS, or ZIP
• Whether the PowerShell Universal service also runs as a gMSA
• Whether the following command returns `True` on the PowerShell Universal server:
Test-ADServiceAccount <TARGET_GMSA>
Please do not include the actual account or domain name.
If the gMSA retrieval permission was recently granted through an Active Directory group, please restart the PowerShell Universal service before testing again so the service account receives a refreshed security token.
For a controlled test, please use a minimal script such as:
whoami
If the issue persists on version 2026.2.1 or later, please provide the relevant sanitized PowerShell Universal log entries and the corresponding Windows Security event 4625, retaining the timestamp, time zone, Logon Type, Status, and Sub Status.
Because this is a public forum, please sanitize all evidence before posting. Remove credentials, tokens, license keys, cookies, private keys, full connection strings, email addresses, usernames, customer data, tenant or account identifiers, internal domains, hostnames, IP addresses, and private URLs. Please do not upload unredacted HAR files, memory dumps, database backups, or complete configuration files to this public thread.
References:
https://devolutions.net/powershell-universal/release-notes/
Ruben Tapia
