Data for some columns missing when updating data for a UDTable when using Set-UDElement
I have a page where a table and column are defined but then the data is set upon an event such as a click event from another object. I use Set-UDElement to set the data and for some reason some of the columns are empty while others are fine. If I load the table using the same query at page load time all of the data comes in fine.
Product: PowerShell Universal
Version: 5.0.15
All Comments (2)
Can you provide a little snippet of code? It might help folks try it out and see if this is a bug or something else.
Adam Driscoll
Here’s the entire tab.
New-UDTab -Text 'Clusters' -Content {
new-UDGrid -Container -content {
    new-UDGrid -Item -ExtraSmallSize 12 -content {
	    New-UDDynamic -Id 'dyngridclusters' -Content {
            new-UDTypography -Id "lblClusters" -Text "Nutanix and VMWare Clusters"
            $Columns = @(
                New-UDTableColumn -Property ClusterName -Title ClusterName -Filter -FilterType AutoComplete -IncludeInExport -DefaultSortColumn -Render {
                    if ($EventData.ClusterName.Contains("ahv")) {
                        $url = "https://" + $EventData.ClusterName + ":9440"
                        New-UDLink -Text $EventData.ClusterName -Url $url -Style @{ fontSize = "12px" } -OpenInNewWindow
                    else {
                        $url = "https://bap-ny6-vcsa01.bamfunds.net/ui"
                New-UDTableColumn -Property Site -Title Site -Filter -FilterType AutoComplete -IncludeInExport
                New-UDTableColumn -Property HostCount -Title HostCount -Filter -FilterType AutoComplete -IncludeInExport
                New-UDTableColumn -Property Cores -Title Cores -Filter -FilterType AutoComplete -IncludeInExport
                New-UDTableColumn -Property Memory -Title "Memory(TB)" -Filter -FilterType AutoComplete -IncludeInExport -Render {
                    $mem = [math]::Round($EventData.Memory,2)
                    new-UDTypography -Text $mem
                New-UDTableColumn -Property VMsOn -Title VMsOn -Filter -FilterType AutoComplete -IncludeInExport
                New-UDTableColumn -Property vCPU -Title vCPU -Filter -FilterType AutoComplete -IncludeInExport
                New-UDTableColumn -Property vCPURatio -Title vCPURatio -Filter -FilterType AutoComplete -IncludeInExport -Render {
                    if ($EventData.vCPURatio -ge 4.0) {
                        New-UDAlert -Text $EventData.vCPURatio -Severity "error" -Dense -Style @{ fontSize = "12px" }
                    } elseif ($EventData.vCPURatio -ge 3.5){
                        New-UDAlert -Text $EventData.vCPURatio -Severity "warning" -Dense -Style @{ fontSize = "12px" }
                    } else {
                        new-UDTypography -Text $EventData.vCPURatio
                New-UDTableColumn -Property vCPU_Avail -Title vCPU_Avail -Filter -FilterType AutoComplete -IncludeInExport -Render {
                    if ($EventData.vCPU_Avail -lt 0) {
                        New-UDAlert -Text $EventData.vCPU_Avail -Severity "warning" -Dense -Style @{ fontSize = "12px" }
                    } else {
                        new-UDTypography -Text $EventData.vCPU_Avail
                New-UDTableColumn -Property Type -Title Type -Filter -FilterType AutoComplete -IncludeInExport
            $Data = @()
            $count = 0
            $clusters = GetInfraData "Clusters_view" "ClusterName"
            foreach ($cluster in $clusters) {
                $count++
                $item = @{ClusterName = $cluster.ClusterName; Site = $cluster.Site; HostCount = $cluster.Host_Count; Cores = $cluster.Cores; Memory = $cluster.Memory; VMsOn = $cluster.VMs; vCPU = $cluster.vCPU; vCPURatio = $cluster.vCPU_Ratio; vCPU_Avail = $cluster.vCPU_Avail; Type = $cluster.Type}
                $Data = $Data += $item
            $clustersBYtype = GetInfraData "Clusters_by_type_view"
            $clustersBYvendor = GetInfraData "Clusters_by_vendor_view"
            $Chart1 = New-UDChartJS -Data $clustersBYtype -DataProperty Clusters -LabelProperty Type -Type 'bar' -DatasetLabel "Type" -Id 'chart_type' -OnClick {
                $tbl = Get-UDElement -Id 'tblClusters'
                $Data2 = @()
                $count = 0
                    $count++
                    $Data2 = $Data2 += $item
                $filteredData = $Data2 | Where-Object { $_.Type -eq $EventData.Label }
                Set-UDElement -Id 'tblClusters' -Properties @{Data=$filteredData }
            $Chart2 = New-UDChartJS -Data $clustersBYvendor -DataProperty Clusters -LabelProperty Vendor -Type 'bar' -DatasetLabel "Vendor" -Id 'chart_vendor' -OnClick {
            New-UDGrid -Container -Spacing 8 -Content {
		        New-UDGrid -Item -ExtraSmallSize 3 -Content {
			        $Chart1
                    $Chart2
            New-UDStyle -Style '
                .MuiTableCell-root {
                padding: 3px;
                font-size: 12px;
            }' -Content {
            New-UDTable -Id 'tblClusters' -Columns $Columns -Data $Data -Dense -ShowSort -ShowFilter -Paging -PageSize 25 -Export
        } -LoadingComponent {
        New-UDProgress -Circular
    } -Dynamic
