Script on portal, Timeout of 30 seconds
(anonymous user)
I use Portal to provide access to scripts. Everything was working fine, but all of a sudden, it seems there’s a 30-second timeout in Portal. That is, if the script doesn’t finish within 30 seconds, I get an error on Portal, but the script keeps running in the background and works as expected.
19eeb4747d5bfe9a98708047304551136fbe0d3a
Does anyone know how to increase the timeout for Portal? I opened a ticket, and they told me to modify Kestrel with:
“Limits”: {
“RequestTimeout”: “00:02:00”
But it still doesn’t work.
Thank you for your feedback.
All Comments (1)
I can reproduce this. It looks like it is hard coded to 30 seconds in the portal. This will be resolved in 5.2.
Adam Driscoll
