Hi everyone,
Apologies if this has been asked before—I may not have been using the best search terms.
We’re using PSU, specifically the Automation/Scripts feature, to set up a process where scripts can run sequentially and depend on the success or failure of previous scripts. This is a big improvement for us, as we currently just run scripts on fixed schedules.
Here’s the workflow we’re aiming for:
From what I’ve found so far, the only way to achieve this is by creating a single PowerShell script to handle the entire workflow and scheduling it for 10 PM.
Below is what we cooked up.
Before I go down that path, I just wanted to check if PSU has any built-in features that could simplify this process.
Thanks in advance for any guidance!
Import-Module -Name Universal
$ErrorActionPreference = "Stop"
$AppToken = "sometoken"
try {
$Script = Get-PSUScript -Name 'test-process1.ps1' -AppToken $AppToken
$execJob = Invoke-PSUScript -Script $Script -AppToken $AppToken
Wait-PSUJob -Job $execJob -AppToken $AppToken
$execJob = Get-PSUJob -Id $execJob.Id -AppToken $AppToken
If ($execJob.Status -ne "Completed") {
Throw "test-process0: Error in test-process1"
} Else {
$Script = Get-PSUScript -Name 'test-process2.ps1' -AppToken $AppToken
Throw "test-process0: Error in test-process2"
} Else {
$Script = Get-PSUScript -Name 'test-process3.ps1' -AppToken $AppToken
Throw "test-process0: Error in test-process3"
} catch {
$errmsg = $_.Exception.Message
throw $errmsg
}Product: PowerShell Universal Version: 5.1.2
Recommended Answer
There isn’t something specific like this built into PSU. That said, it has been brought up in the past and we have an open issue for it here: Workflows · Issue #1393 · ironmansoftware/powershell-universal · GitHub
Honestly, I hadn’t realized how desired this was (based on the upvotes on the issue) and we should schedule this for an upcoming release.
Adam Driscoll
Adam Driscoll
