PSU 5 Beta 3 Docker connection string error
(anonymous user)
Product: PowerShell Universal
Version: 5.0.0 Beta3
Im using these image from docker hub: ironmansoftware/universal:5.0.0-beta3-ubunutu-20.04-ps-7.3.0
I followed the instructions from: Docker | v5 | PowerShell Universal
But if i’m adding these
ENV Data__ConnectionString /home/data/database.db
i get the following error:
at System.Data.Common.DbConnectionOptions.GetKeyValuePair(String connectionString, Int32 currentPosition, StringBuilder buffer, Boolean useOdbcRules, String& keyname, String& keyvalue)
at System.Data.Common.DbConnectionOptions.ParseInternal(Dictionary2 parsetable, String connectionString, Boolean buildChain, Dictionary2 synonyms, Boolean firstKey)
at System.Data.Common.DbConnectionOptions…ctor(String connectionString, Dictionary2 synonyms, Boolean useOdbcRules) at System.Data.Common.DbConnectionStringBuilder.set_ConnectionString(String value) at Microsoft.Data.Sqlite.SqliteConnectionStringBuilder..ctor(String connectionString) at Microsoft.EntityFrameworkCore.Sqlite.Storage.Internal.SqliteDatabaseCreator.Exists() at Microsoft.EntityFrameworkCore.Migrations.HistoryRepository.Exists() at Microsoft.EntityFrameworkCore.Migrations.Internal.Migrator.Migrate(String targetMigration) at Microsoft.EntityFrameworkCore.RelationalDatabaseFacadeExtensions.Migrate(DatabaseFacade databaseFacade) at PowerShellUniversal.SQLite.DatabaseFeature.InitializeDatabase(IConfiguration configuration) in C:\actions-runner\_work\universal\universal\src\PowerShellUniversal.SQLite\Plugin.cs:line 50 at Universal.Server.Services.SystemPluginService..ctor(IConfiguration configuration) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Services\SystemPluginService.cs:line 55 at Universal.Server.Startup.ConfigureServices(IServiceCollection services) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Startup.cs:line 64 at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor) at System.Reflection.MethodBaseInvoker.InvokeDirectByRefWithFewArgs(Object obj, Span1 copyOfArgs, BindingFlags invokeAttr)
at System.Reflection.MethodBaseInvoker.InvokeWithOneArg(Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.InvokeCore(Object instance, IServiceCollection services)
at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.UseStartup(Type startupType, HostBuilderContext context, IServiceCollection services, Object instance)
at Microsoft.Extensions.Hosting.HostBuilder.InitializeServiceProvider()
at Microsoft.Extensions.Hosting.HostBuilder.Build()
at Universal.Server.Program.Main(String args) in C:\actions-runner_work\universal\universal\src\Universal.Server\Program.cs:line 36
Unhandled exception. System.ArgumentException: Format of the initialization string does not conform to specification starting at index 0.
All Comments (0)
Closed
