Login after Installation does not work (admin / admin)
(anonymous user)
Product: PowerShell Universal
Version: 4.2.11 (7611461404)
Hello
I installed Powershell Universal several month, probalby years ago on a test server. Acutally I didn’t use it. Today while I tried to build a new dashboard, I did realize, that my used version is very old (2.x*). So then I thought, let’s install the newest verison, which is 4.2.11. After uninstalling the old version, I installed the newest one. Now I’m not able to login anymore with the default admin account.
d43bdd9d1f4847c95525758c23c2bb567e1cf97d
Could anybody help me? Thank you
All Comments (1)
(anonymous user)
You may have some configuration files from the previous version still around. I would do a fresh install, uninstall what you got and manually review for the listed directories located here: Uninstall - PowerShell Universal for your platform. Had something similar happen to me on a Windows box, removing C:\ program data \ PowerShellUniversal (default location for me) cleared it up after installing a fresh copy.
