Product: PowerShell Universal
Version: 4.2.1Issue
There seems to be an issue where if a chart, is set to -Type 'line', it ignores the Options that are supplied and uses it’s own.
Example Setup
$Data = @(
[PSCustomObject]@{
Date = 'Oct 2019'
Total = 54
[PSCustomObject]@{
Date = 'Nov 2019'
Total = 15
[PSCustomObject]@{
Date = 'Dec 2019'
Total = 5
$DataSet = New-UDChartJSDataset -DataProperty 'Total' -AdditionalOptions @{
fill = $false
$ChartSplat = @{
Type = 'line'
Data = $Data
Dataset = $DataSet
LabelProperty = 'Date'
Options = @{
plugins = @{
legend = @{
display = $false
maintainAspectRatio = $false
responsive = $true
New-UDChartJS @ChartSplatIf we just inspect the hashtable that the command produces, we can see that our supplied options have been dropped in favour of different options
Name Value
data {[datasets, System.Collections.Hashtable[]],
chartType line
assetId
loadData
type ud-chartjs
onClick
id b2b7ca50-a2c2-4a48-9eeb-e934e6c50905
options {[tension, 0.4], [fill, True]}
isPlugin TrueSimply changing the chart type to ‘bar’ and inspecting the hashtable again, we see:
Name Value
chartType bar
assetId
loadData
type ud-chartjs
onClick
id c8b59f19-3366-47e3-8578-482e1e3f7d63
options {[maintainAspectRatio, False], [plugins, Syste
isPlugin TrueNote: This happens whether a dataset is used or not
The below line from the Cmdlet definition looks sus, but I’m supplying options, and I should be in the ‘Datasets’ parameterset when using a dataset.
f ($PSCmdlet.ParameterSetName -eq 'Simple') {
if (-not $DatasetLabel) {
$DatasetLabel = $DataProperty
if (-not $Options -and $Type -eq 'Line') {
$Options = @{
fill = $true
tension = 0.4
$Dataset += New-UDChartJSDataset -Data $Data -DataProperty $DataProperty -Label $DatasetLabel -BackgroundColor $BackgroundColor -BorderColor $BorderColor -HoverBackgroundColor $HoverBackgroundColor -HoverBorderColor $HoverBorderColor -BorderWidth $BorderWidth -AdditionalOptions $Options
}I change my suspicion to be the below from the New-UDChartJS cmdlet definition:
if (-not ($MyInvocation.BoundParameters.ContainsKey('LoadData'))) {
Foreach ($datasetDef in $Dataset) {
if ($Type -eq 'Line' -and $datasetDef.Options -eq $null) {
$Options = @{
fill = $true
tension = 0.4
if ($datasetDef.DataProperty) {
$datasetDef.data = @($Data | ForEach-Object { $_.($datasetDef.DataProperty) })
}$null should be on the left hand side of that equality check - but that’s not the issue.
The $datasetDef.Options is not being set if it’s null here - the main $Options of the chart are instead being overwritten.
