Hello Adam,
we have now updated from 3.7.x to 4.1.4 and if we configure our Wildcard certificate for SSL the Powershell Universal Service does not start any more. In 3.7.x we configured it via Thumbprint because Subject also had issues but in 4.1.4 it is not working at all.
"Kestrel": {
"Endpoints": {
"HTTP": {
"Url": "http://*:80",
"HTTPS": {
"Url": "https://*:443",
"Certificate": {
"Thumbprint": "12345679",
"Store": "My",
"Location": "LocalMachine",
"AllowInvalid": "true"
"RedirectToHttps": "true"
"Plugins": [
"UniversalAutomation.LiteDBv5"
"Data": {
"RepositoryPath": "D:\\UniversalAutomation\\Repository",
"ConnectionString": "D:\\UniversalAutomation\\database.db"
}2023-10-04 20:39:10.773 +02:00 [DBG] Registered model binder providers, in the following order: ["Microsoft.AspNetCore.Mvc.ModelBinding.Binders.BinderTypeModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.ServicesModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.BodyModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.HeaderModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.FloatingPointTypeModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.EnumTypeModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.DateTimeModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.TryParseModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.SimpleTypeModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.CancellationTokenModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.ByteArrayModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.FormFileModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.FormCollectionModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.KeyValuePairModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.DictionaryModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.ArrayModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.CollectionModelBinderProvider","Microsoft.AspNetCore.Mvc.ModelBinding.Binders.ComplexObjectModelBinderProvider"] 2023-10-04 20:39:10.959 +02:00 [FTL] Fatal error starting PowerShell Universal. System.InvalidOperationException: The requested certificate *.de.my-companyname.com could not be found in LocalMachine/My with AllowInvalid setting: True. at Microsoft.AspNetCore.Server.Kestrel.Https.CertificateLoader.LoadFromStoreCert(String subject, String storeName, StoreLocation storeLocation, Boolean allowInvalid) at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Certificates.CertificateConfigLoader.LoadFromStoreCert(CertificateConfig certInfo) at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Certificates.CertificateConfigLoader.LoadCertificate(CertificateConfig certInfo, String endpointName) at Microsoft.AspNetCore.Server.Kestrel.KestrelConfigurationLoader.Reload() at Microsoft.AspNetCore.Server.Kestrel.KestrelConfigurationLoader.Load() at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServerImpl.BindAsync(CancellationToken cancellationToken) at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServerImpl.StartAsync[TContext](IHttpApplication`1 application, CancellationToken cancellationToken) at Microsoft.AspNetCore.Hosting.GenericWebHostService.StartAsync(CancellationToken cancellationToken) at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken) at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token) at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token) at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host) at Universal.Server.Program.<>c__DisplayClass3_0.<Main>b__0(Options o) in C:\actions-runner\_work\universal\universal\src\Universal.Server\Program.cs:line 72 2023-10-04 20:45:54.608 +02:00 [DBG] Hosting starting
I think the asterisks is the reason for the issue if it is used in variables later the binding.
Product: PowerShell Universal Version: 4.1.4
I’m unaware of any changes made to this in the v4 codebase aside from updating to newer versions of .NET. I would recommend trying to run the script in the KB article to see if it can find the cert.
Ironman Software Support
Adam Driscoll
Hey Tyler,
Were you able to get your wildcard cert working? I’m new to Powershell Universal, so I don’t know how it worked in the past, but I am having the same problem with the same error message in version 4.2.11
I got mine working. I did two things:
Now it is working as expected.
