New-UDTableColumn -Render New-UDSelect issue
(anonymous user)
I am having trouble with New-UDTableColumn -Render having New-UDSelect, the selections are showing however it does not update the actual value. The output still is set to the default value and not the one I selected on the New-UDSelect items. I am still new and learning so may be a problem with how I update or sync the udelement. Please help. Thanks.
$Columns = @(
New-UDTableColumn -Property CatalogName -Title CatalogName
                    New-UDTableColumn -id 'element_cloneimage' -Property CloneImage -Title CloneImage -Render {
                    $cloneimagevalue = $eventdata.CloneImage
                    $cloneimagename = $cloneimagevalue.name
                    $basetablefilter = $basetable | where {$_ -match $cloneimagename}
                            New-UDSelect -id Select_$($EventData.CloneImage) -Option {
                                     foreach ($basename1 in $basetablefilter) {
                                        New-UDSelectOption -Name $basename1 -Value $basename1
                            } -DefaultValue $cloneimagename -OnChange {
                            Sync-UDElement -id 'element_cloneimage'
All Comments (13)
(anonymous user)
Any one care to answer my problem, I need this to work. Thanks in advance.
(anonymous user)
Anyone has an idea ?
(anonymous user)
Can you provide the rest of your code that has the New-UDTable?
What is the goal?
(anonymous user)
@AnonymousUser Is the goal to have a column in a table that only updates that specific row when a drop down selection is made?
(anonymous user)
@AnonymousUser that is correct. There is a defaultvalue set. But when I try to make a selection, it does not update the specific row, when I proceed to create the table, the row still contains the defaultvalue instead of the selection I made.
(anonymous user)
$Columns = @(
                    $cloneimagevalue = $cloneimagevalue.name
                    $cloneimagename = $eventdata.Baseimage
                    $active_catalog = $eventdata.catalogname
                            New-UDSelect -id "Select_$($EventData.CloneImage)" -Option {
                            } -DefaultValue $cloneimagevalue -OnChange {
                            Sync-UDElement -Id 'Rollout'
                            Show-UDToast -Message "$EventData[0]"
                            ($mcupdatelist | where catalogname -eq $active_catalog).cloneimage = $EventData[0]
                    New-UDTableColumn -Id 'element_snapshot' -Property SnapShot -Title SnapShot -Render {
                    $cloneimagevalue = $eventdata.Baseimage
                    $snapshottablefilter = $snapshottable | where name -match $cloneimagevalue
                            New-UDSelect -id "Selected_snapshot" -Option {
                                     foreach ($baseinfo in $snapshottablefilter ) {
                                        $snapshotinfo = $baseinfo.name
                                        New-UDSelectOption -Name $snapshotinfo -Value $snapshotinfo
                            } -DefaultValue $eventdata.snapshot -OnChange {
                            ($mcupdatelist | where catalogname -eq $active_catalog).snapshot = $Eventdata[0]
                    New-UDTableColumn -Property BaseImage -Title BaseImage
                    New-UDTableColumn -Property StorageResource -Title StorageResource
                    New-UDTableColumn -Property HostResource -Title HostResource
                    New-UDTableColumn -Property Engineer -Title Engineer
                    New-UDTable -Id 'mcupdate_table' -Data $mcupdatelist -Columns $Columns -Title 'Clone and Snapshot Table' -ShowSearch -ShowPagination -ShowSelection -Dense -OnRowSelection {
                    $mcupdate_table = (Get-UDElement -Id 'mcupdate_table').selectedRows
                    $Item = $EventData
                    Show-UDToast -Message "$($Item | out-string)"  -Duration 10000
(anonymous user)
$Columns = @(
        $basetablefilter = $basetable | where { $_ -match $cloneimagename }
    $Item = $EventData
(anonymous user)
thx having a look at it.
(anonymous user)
Did you see an example where New-UDTableColumn -ID 'Test' was being used with Sync-UDElement?
Also what version are you on?
(anonymous user)
No, I just experimented with different components because I could not figure out how to. Version is 3.9.5
(anonymous user)
@AnonymousUser I’m unsure if it’s possible to ascertain from which row a UDSelect is invoked. As of now, I haven’t stumbled upon a method to achieve this. That said, the -OnRowSelection feature might help. Additionally, while the sample code can shed some light, a visual representation—maybe in the form of a spreadsheet—showcasing your desired result before and after might be helpful. I used -LoadData, but feel free to stick to your approach. Since I frequently work with databases, I based my examples on them, using them as a template.
$Page:Data = foreach ($Item in (0..2)) {
    $Item = $Item.ToString()
        Col1 = $Item
        Col2 = $Item
        Col3 = $Item
New-UDTable -Id 'Table' -LoadData {
    $TableData = ConvertFrom-Json $Body
    $Page:Data | Out-UDTableData -Page $TableData.page -TotalCount $Count.count -Properties $TableData.properties
} -Columns @(
    New-UDTableColumn -Property 'Col1' -Title 'Col1'
    New-UDTableColumn -Property 'Col2' -Title 'Col2'
    New-UDTableColumn -Property 'Col3' -Title 'Col3'
    New-UDTableColumn -Property 'CloneImage' -Title 'CloneImage' -Render {
        Show-UDToast ('$EventData {0}' -f ([PSCustomObject]$EventData | Select-Object *) | Out-String) -Duration 10000
        New-UDSelect -Id "Select_$($EventData.Col1)" -DefaultValue '3' -Option {
            foreach ($Item in (3..9)) {
                New-UDSelectOption -Name $Item -Value $Item
        } -OnChange {
            Show-UDToast ('Was Selected with UDSelect:{0}. Row(s) Selected with checkboxes (Would need to be implemented): {1} ' -f $EventData[0], $Page:SelectedRows) -Duration 10000
            $Page:Data = foreach ($Item in $Page:Data) {
                    Col1 = $EventData[0]
                    Col2 = $Item.Col2
                    Col3 = $Item.Col3
            Sync-UDElement -id 'Table'
) -ShowSelection -OnRowSelection {
    $Page:Table = Get-UDElement -Id "Table"
    $Page:SelectedRows = $Page:Table.selectedRows
This post shows how to retrieve the UDSelect value from each selected row in a UDTable
Product: PowerShell Universal Version: 3.0.6 Hello, I have a UDTable using columns, 1 column has rendering using a UDSelect. The table also has selections enabled for the rows. I know how to get the selected rows details, but how can I get the UDSelect value from each selected row? Thanks for any help!
Hope this helps.
(anonymous user)
@AnonymousUser thans for your suggestion. I am trying it out but no data was populating. Where did you get this data?
Can you show me the content?
(anonymous user)
Can you provide code that you are trying. All data is there. It’s just sample numbers in $Page:Data
