Problem connection Visual Studio code to Powershell Universal
Resolved
(anonymous user)
Product: PowerShell Universal
Version: 4.0.9
Hi All,
I’m trying to connect Visual Studio Code to a new instance of Powershell Universal. For some reason I get a 401 Unauthorized error. I’m pretty sure the token is correct. Any tips?
Terminal Visual Studio Code:
PS C:\Users\user> Import-Module (Join-Path ‘c:\Users\behvoermanm.vscode\extensions\ironmansoftware.powershell-universal-4.0.2\out’ ‘Universal.VSCode.psm1’)
PS C:\Users\user> Install-UniversalModule -Version ‘4.0.9’
PS C:\Users\user> Connect-PSUServer -ComputerName ‘http://localhost:5000’ -AppToken ‘eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJodHRwOi8vc2NoZW1hcy54bWxzb2FwLm9yZy93cy8yMDA1LzA1L2lkZW50aXR5L2NsYWltcy9uYW1lIjoiYWRtaW4iLCJodHRwOi8vc2NoZW1hcy54bWxzb2Fw
Lm9yZy93cy8yMDA1LzA1L2lkZW50aXR5L2NsYWltcy9oYXNoIjoiYmRiYjkxZDgtN2NlYS00YjRkLTkyZDAtMWQ4OGE5NTE1Y2FjIiwic3ViIjoiUG93ZXJTaGVsbFVuaXZlcnNhbCIsImh0dHA6Ly9zY2hlbWFzLm1pY3Jvc29mdC5jb20vd3MvMjAwOC8wNi9pZGVudGl0eS9jbGFpbXMvcm9sZSI6IkFkbWluaXN0cmF0b3IiLCJuYmYiO
jE2OTE0OTAxNjEsImV4cCI6MjE0OTQxMzcyMCwiaXNzIjoiSXJvbm1hblNvZnR3YXJlIiwiYXVkIjoiUG93ZXJTaGVsbFVuaXZlcnNhbCJ9.lj-Y5nXW5aMk-x_VztgRgQJFmZ-z4u64jaY3Y0TO090’
Connect-PSUServer: Call failed with status code 401 (Unauthorized): GET http://localhost:5000/api/v1/accessible
98e36b475c38cc4a227dc9467eafaf3e7572b9af
Logging from systemLog.txt: http:// has been replaces to http
2023-08-08 12:33:49.808 +02:00 [INF] Request starting HTTP/1.1 GET httplocalhost:5000/api/v1/configuration/list/ application/json -
2023-08-08 12:33:49.808 +02:00 [VRB] All hosts are allowed.
2023-08-08 12:33:49.808 +02:00 [DBG] No response compression available, the Accept-Encoding header is missing or invalid.
2023-08-08 12:33:49.808 +02:00 [VRB] Performing protect operation to key {26f40cca-1850-4c87-8026-1351e8838832} with purposes ('D:\dashboards\PowershellUniversal\Install', ‘SessionMiddleware’).
2023-08-08 12:33:49.808 +02:00 [DBG] The request path /api/v1/configuration/list/ does not match a supported file type
2023-08-08 12:33:49.808 +02:00 [DBG] The request path does not match the path filter
2023-08-08 12:33:49.808 +02:00 [DBG] Request matched endpoint ‘UniversalAutomation.ConfigurationController.ListItems (Universal.Server)’
2023-08-08 12:33:49.813 +02:00 [VRB] Performing protect operation to key {26f40cca-1850-4c87-8026-1351e8838832} with purposes ('D:\dashboards\PowershellUniversal\Install', ‘SessionMiddleware’).
2023-08-08 12:33:49.813 +02:00 [DBG] Static files was skipped as the request already matched an endpoint.
2023-08-08 12:33:49.813 +02:00 [DBG] Endpoint ‘UniversalAutomation.ConfigurationController.ListItems (Universal.Server)’ already set, skipping route matching.
2023-08-08 12:33:49.817 +02:00 [INF] Request finished HTTP/1.1 GET httplocalhost:5000/api/v1/configuration/list/ application/json - - 401 0 - 9.6702ms
2023-08-08 12:33:51.499 +02:00 [INF] Request starting HTTP/1.1 GET httplocalhost:5000/api/v1/accessible - -
2023-08-08 12:33:51.499 +02:00 [VRB] All hosts are allowed.
2023-08-08 12:33:51.499 +02:00 [VRB] This request accepts compression.
2023-08-08 12:33:51.500 +02:00 [VRB] Performing protect operation to key {26f40cca-1850-4c87-8026-1351e8838832} with purposes ('D:\dashboards\PowershellUniversal\Install', ‘SessionMiddleware’).
2023-08-08 12:33:51.500 +02:00 [DBG] The request path /api/v1/accessible does not match a supported file type
2023-08-08 12:33:51.500 +02:00 [DBG] The request path does not match the path filter
2023-08-08 12:33:51.500 +02:00 [DBG] Request matched endpoint ‘UniversalAutomation.AliveController.Accessible (Universal.Server)’
2023-08-08 12:33:51.504 +02:00 [VRB] Performing protect operation to key {26f40cca-1850-4c87-8026-1351e8838832} with purposes ('D:\dashboards\PowershellUniversal\Install', ‘SessionMiddleware’).
2023-08-08 12:33:51.504 +02:00 [DBG] Static files was skipped as the request already matched an endpoint.
2023-08-08 12:33:51.505 +02:00 [DBG] Static files was skipped as the request already matched an endpoint.
2023-08-08 12:33:51.505 +02:00 [DBG] Endpoint ‘UniversalAutomation.AliveController.Accessible (Universal.Server)’ already set, skipping route matching.
2023-08-08 12:33:51.508 +02:00 [DBG] Connection id “0HMSNVBPG75EE” completed keep alive response.
2023-08-08 12:33:51.508 +02:00 [INF] Request finished HTTP/1.1 GET httplocalhost:5000/api/v1/accessible - - - 401 0 - 9.7233ms
(anonymous user)
Recommended Answer
Not sure what really the problem was. I’ve generated the token on user admin, but i’ve got Windows authentication enabled.
I just generated a token on my Windows account and with this token the connection succeeds
All Comments (1)
