Invoke-RestMethod authorization problem
Resolved
(anonymous user)
Product: PowerShell Universal
Version: 4.0.2
I can run this script from a powershell window with no problem:
Invoke-RestMethod https://nsd.us002-rapididentity.com/api/rest/admin/connect/exportProject -Authentication “Basic” -Credential $cred -OutFile “main.zip”
but when I add it to a PSU script like this:
$response = Invoke-RestMethod https://nsd.us002-rapididentity.com/api/rest/admin/connect/exportProject -Authentication “Basic” -Credential $secret:ricloud -OutFile “main.zip”
I get this error:
[error] {“httpStatusCode”:401,“message”:“Insufficient Authorization”,“details”:“The Authorization HTTP Header is missing or malformed”}
I know $secret:ricloud is correct, because I use it in several endpoint scripts. Any idea why I am getting this error?
cheers,
ski
(anonymous user)
Recommended Answer
Adam,
Figured this out. The powershell window was caching a different set of credentials. My bad.
cheers,
ski
(anonymous user)
Ok, this is strange. I can get it to work with a Post method. The file is downloaded ok, but I do get a 405 error as the endpoint I am using doesn’t like Post methods. For now I can do this, but I would like to know why the Get method does not work
You could try to use cookie auth directly. I’m not sure why what you are trying isn’t working.
        Invoke-RestMethod  https://nsd.us002-rapididentity.com/api/v1/signin -Method Post -Body (@{
                Username = $secret:ricloud.UserName
                Password = $secret:ricloud.GetNetworkCredential().Password
            } | ConvertTo-Json) -SessionVariable Session -ContentType "application/json"
$response = Invoke-RestMethod https://nsd.us002-rapididentity.com/api/rest/admin/connect/exportProject -WebSession $Session -OutFile “main.zip”
Adam Driscoll
(anonymous user)
Adam,
cheers,
ski
