PSU 2.6.0 hosted in IIS stop working when using InProcess
Resolved
(anonymous user)
Log
Unhandled exception. System.InvalidOperationException: A circular dependency was detected for the service of type ‘PowerShellUniversal.IConfigurationService’.
System.Collections.Generic.IEnumerable<Microsoft.Extensions.Hosting.IHostedService> → Microsoft.Extensions.Hosting.IHostedService(UniversalAutomation.StartupService) → UniversalAutomation.IGitSyncService(UniversalAutomation.GitSyncService) → UniversalAutomation.IGitService(UniversalAutomation.Git.GitService) → PowerShellUniversal.IConfigurationService(Universal.Server.Services.ConfigurationService) → Microsoft.AspNetCore.Hosting.Server.IServer(Microsoft.AspNetCore.Server.IIS.Core.IISHttpServer) → Microsoft.AspNetCore.Authentication.IAuthenticationSchemeProvider(Universal.Server.Services.MyAuthenticationSchemeProvider) → PowerShellUniversal.IConfigurationService
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteChain.CheckCircularDependency(Type serviceType)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.CreateCallSite(Type serviceType, CallSiteChain callSiteChain)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.<>c__DisplayClass7_0.b__0(Type type)
at System.Collections.Concurrent.ConcurrentDictionary2.GetOrAdd(TKey key, Func2 valueFactory)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.GetCallSite(Type serviceType, CallSiteChain callSiteChain)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.CreateArgumentCallSites(Type serviceType, Type implementationType, CallSiteChain callSiteChain, ParameterInfo[] parameters, Boolean throwIfCallSiteNotFound)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.CreateConstructorCallSite(ResultCache lifetime, Type serviceType, Type implementationType, CallSiteChain callSiteChain)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.TryCreateExact(ServiceDescriptor descriptor, Type serviceType, CallSiteChain callSiteChain, Int32 slot)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.TryCreateExact(Type serviceType, CallSiteChain callSiteChain)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteFactory.TryCreateEnumerable(Type serviceType, CallSiteChain callSiteChain)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.ServiceProviderEngine.CreateServiceAccessor(Type serviceType)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.ServiceProviderEngine.GetService(Type serviceType, ServiceProviderEngineScope serviceProviderEngineScope)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.ServiceProviderEngineScope.GetService(Type serviceType)
at Microsoft.Extensions.DependencyInjection.ServiceProviderServiceExtensions.GetService[T](IServiceProvider provider)
at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
at Universal.Server.Program.<>c__DisplayClass3_0.b__0(Options o) in D:\a\universal\universal\src\Universal.Server\Program.cs:line 55
at CommandLine.ParserResultExtensions.WithParsed[T](ParserResult1 result, Action1 action)
at Universal.Server.Program.Main(String[] args) in D:\a\universal\universal\src\Universal.Server\Program.cs:line 43
Product: PowerShell Universal
Version: 2.6.0
Recommended Answer
This one doesn’t exist by default: PSU_DISABLE_WIN_AUTH
You could add it to disable this functionality.
The APP_POOL_ID is created internally by IIS so you won’t see it listed in your system environment variables.
Adam Driscoll
All Comments (13)
I’ve opened an issue for this and will get it in the 2.6.1 release.
Adam Driscoll
