RDM installation documentation for Fedora is wron
Hi Devolutions,
I've just come across some mistakes in the RDM install docs for RedHat-based systems. While the Debian version seems fine, the RPM looks like a copy/paste version of the Debian section
I'm referring to this part of the documentation:
https://docs.devolutions.net/rdm/installation/client/?tab=linux#repo-method
For example the cloudsmith's repo setup script points to the .deb link instead of the rpm one. Also the documented install command is dnf-get install (probably copy/past of apt-get install) and package name is wrong (remotedesktopmanager instead of RemoteDesktopManager)
I haven't tested / proof-red the manual configuration script snippet.
Best Regards,
Fabian
All Comments (1)
Thank you for bringing this to our attention. We’ve updated all the code blocks in the RedHat and RedHat-based systems section.
Jean-Sébastien Simard
Learning experience team leader
