certifcate template are not the same any more in de WEB and RDM
1 vote
The Certificate Template are not the same any more in de WEB and RDM
if a certifcate is upload by RDM you can't open it or download any more in the WEB interface
the old structure was beter then the new one.
now certificate can be download and new password can be used to store the PFX. this is less secure because certifcate can be saved with new password who aren't stored or be verified
please fix this
All Comments (1)
Thank you for your feedback.
I would like to better understand your situation to make sure we address it properly.
When you mention the new certificate templates, are you referring to the Certificate X509 entry type? Also, could you clarify what behavior you expect between RDM and the Web interface?
Regarding the download limitation, we understand your concern, especially around the ability to re-protect the PFX file with a new password. From your perspective, what would be a more secure or appropriate way to handle this?
If you have specific examples or steps to reproduce the issue, that would also help us investigate further.
Thank you
Marc-Andre Bouchard
