Import Custom variable into Devolutions Hub Business
Good afternoon,
Is it possible to import Custom variables into a Hub Business environment using PowerShell?
Kind regards,
Ron Bouwmeester
Recommended Answer
It is possible to import custom variables into a Hub Business environment using PowerShell, though the current solution is a workaround. You can use the Import-RDMCustomVariable cmdlet, which accepts a JSON file as input.
Here is an example of the JSON file format (custom_variables.json):
      "Name": "CV1",
      "Value": "Some value",
      "Description": "my custom variable 1"
      "Name": "SomePort",
      "Value": "5432",
      "Description": "Some port"
Import command:
  Import-RDMCustomVariable -FilePath "C:\path\to\custom_variables.json" -ImportAction ReplaceList -VariableScope DataSource
The ImportAction parameter controls how duplicates are handled:
  • ReplaceList — replaces all existing variables with the imported list
  • AddNewItems — only adds variables that don't already exist
  • AddAndUpdate — adds new variables and updates existing ones
The VariableScope parameter controls where the variables are stored:
  • DataSource — data source settings
  • Vault — current vault
  • UserVault — current user vault
  • Option — application options
Please note that this is a workaround, as dedicated cmdlets for managing custom variables at the vault level are not yet available. A ticket has been logged to add proper cmdlet support for this scenario, and it will be addressed in a future release.
Do not hesitate to reach out if you have any further questions.
Maxime
All Comments (7)
      "Name": "CV1",
      "Name": "SomePort",
      "Value": "5432",
Import command:
Maxime
Hello Maxime,
Thank you for your reply.
I have created the following script:
$ds = Get-RDMDataSource -Name "Devolutions Hub Business"
Set-RDMCurrentDataSource $ds
$repository = Get-RDMRepository -Name "<VaultName>" ;Set-RDMCurrentRepository $repository
Import-RDMCustomVariable -FilePath "<FilePath>\config.json" -ImportAction AddAndUpdate -VariableScope Vault
But when I execute the import startement I get the following error:
Import-RDMCustomVariable: The file format (.json) is not supported.
Can you give some advice?
In advance thank you for your reply.
Kind regards,
Ron Bouwmeester
Hello Ron,
Before investigating further, could you run the following command to verify that your file is valid JSON?
Test-Json -Path "<FilePath>\config.json"
If it returns False, the file content is malformed and will need to be fixed before importing.
Maxime
Hello Maxime,
Thank you very much for your reply.
Test-Json: Cannot parse the JSON.
Th content of the json file is:
"Name": "CV1",
"Name": "SomePort",
"Value": "5432",
Kind regards,
Ron Bouwmeester
Hello Ron,
The issue is that your JSON file is missing the surrounding array brackets [ and ]. The file should look like this:
        "Name": "CV1",
        "Name": "SomePort",
        "Value": "5432",
Once corrected, Test-Json should return True and the import will work.
Maxime
Hello Maxime,
Thank you for your advice. It works perfect now.
Thank you for the support.
Kind regards,
Ron Bouwmeester
Hello Ron,
You are welcome! Please reach out to us if you need anything else.
Maxime
