Hello everyone,
I'm currently experimenting with the Devolutions Server via Docker in a test environment.
So far, the environment is running smoothly and without errors via the WebUI with version 2026.1.7.0.
The DPSMain_xxx log appears to be error-free.
However, I am unable to establish a connection from an RDM to the Devolutions Server.
The connection does not work on Windows, macOS, or iPadOS.
In Windows RDM 2026.1.12.0, I receive this error message:
System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
---> System.Security.Authentication.AuthenticationException: Cannot determine the frame size or a corrupted frame was received.
at System.Net.Security.SslStream.GetFrameSize(ReadOnlySpan`1 buffer)
at System.Net.Security.SslStream.EnsureFullTlsFrameAsync[TIOAdapter](CancellationToken cancellationToken, Int32 estimatedSize)
at System.Runtime.CompilerServices.PoolingAsyncValueTaskMethodBuilder`1.StateMachineBox`1.System.Threading.Tasks.Sources.IValueTaskSource<TResult>.GetResult(Int16 token)
at System.Net.Security.SslStream.ReceiveHandshakeFrameAsync[TIOAdapter](CancellationToken cancellationToken)
at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](Boolean receiveFirst, Byte[] reAuthenticationData, CancellationToken cancellationToken)
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken)
--- End of inner exception stack trace ---
at Devolutions.Server.ApiWrapper.RDMSWebClient.RunSynchronous[T](Task`1 task)
at Devolutions.RemoteDesktopManager.Business.DataSources.RDMSWebApiClient.ExecuteAnonymousAction[T](Func`2 action)
at Devolutions.RemoteDesktopManager.Business.DataSources.RDMSWebApiClient.GetPublicWebInstanceInformation()
On macOS RDM 2025.3.10.2, I get this message:
Ungültige Protokollversion
net_auth_SSPI
net_http_ssl_connection_failed
I've already imported my license. Unfortunately, it didn't work.
I also tried two different proxies. No luck.
My docker-compose.yaml follows these instructions:
After doing a bit of searching, I found the EXTERNAL_URL environment variable. Once I added this to my docker-compose file, the RDMs (Windows, macOS, and iPadOS) were able to connect to the Devolutions server.
Here's my test Docker Compose file. As I said, I'm still testing it out / playing around with it ;-)
environment:
# Database connection variables
# Web server configuration
HOSTNAME: dvls.domain.tld
WEB_SCHEME: http
PORT: 5000
EXTERNAL_WEB_SCHEME: https
EXTERNAL_WEB_PORT: 443
EXTERNAL_URL: dvls.domain.tld
# TLS certificate configuration
# Operating mode configuration
DVLS_INIT: false
#DVLS_UPDATE_MODE: ${DVLS_UPDATE_MODE}
#DVLS_BACKUP_PATH: ${DVLS_BACKUP_PATH}
# Initialization mode variables
# System configuration
DVLS_PATH: /opt/devolutions/dvls
#DVLS_TELEMETRY: ${DVLS_TELEMETRY}
#DVLS_ENCRYPTION_CONFIG_B64: ${DVLS_ENCRYPTION_CONFIG_B64}
Could it be that this environment variable is missing from the documentation?
Thanks in advance,
Alex
Recommended Answer
Hi Alex,
Good catch. I'll verify internally.
For now, as you suggested, it seems like we need to update the documentation.
Marc-Antoine Dubois
Hi Alex,
Marc-Antoine Dubois
