RDP does not work on Fedora 43
Resolved
Hi guys, does RDP works? I've installed RDM from flatpak, it does not connect to any RDP session I add compared if I do the same in Windows, where it works fine.
All Comments (4)
It appears to be broken in the new release, please see this post:
https://forum.devolutions.net/topics/52131/fedora-43-kde-flatpak-2025322-previously-working-rdp-sessions-now-fail
I was able to reproduce the issue and have submitted a bug report.
I suggest continuing this discussion in the other forum thread opened by the user to ensure better follow-up and centralized communication.
Carl Marien
Linux Mint 22.3, RDM from Flatpak, same issue here.
Thank you for confirming the behavior on your end.
Since this issue is already being tracked in the other forum thread regarding Fedora 43 and the Flatpak release, I recommend following that discussion for updates and further communication:
We are centralizing information there to ensure proper follow-up and visibility as the investigation progresses.
Thank you for your understanding.
Carl Marien
