Add Credential or Entry to other Entry
1 vote
Hi there,
It is possible to add an Entry to an entry as a subentry. However it's not possible to move subentry to another entry.
Only entry under a folder can be moved or drap/drop.
I guess the problem is that the Folder field in the property of the entry, doesn't list other entries but only folders.
All Comments (1)
Hello Guillaume,
We’ve just improved this feature, so you can now drag and drop an entry onto another to create a sub-entry. This change will be available in the next release (2026.1).
Gabriel Dubois
